How do I get color night vision
Color Night Vision not working
The terminology is really bad. Night vision is strictly black and white. Daytime mode is color, however daytime works in color down to very low light level. Lock the camera in Daytime mode and see the colors at night.
Set night vision mode to “Off”. It’s Wyze-speak for “Color Night Vision”. :rolling_on_the_floor_laughing:
Well, assuming you have sufficient ambient light.
every single comment here is spot on, turn “nightvision” off, if you have enough ambiant light you can get pretty good color vision without the IR lights, And this is the company definition of color night vision. the community knocked out of the park here
Not to beat a dead horse, but the Help Center can be your friend.
Welcome to the Forum, @yisroelfeder! :wave:
I leave Night Vision off on my cameras watching the outside of my house. As others have mentioned, ambient light is the key. I have two 100 watt equivalent LED bulbs outside my garage.
Here is a sample video with my lights off.
Here is a sample video with my LED bulbs on.
Get the crack in your driveway fixed.
It is sealed but discoloring. I used material called Slab. I can live with a discolored look as long as stays sealed.
Here are close up pictures before and after.
