Hold Mode Thermostat
I don’t want to set up any schedules or any kind of automation for my Wyze Thermostat, I juist want to use the dial or the app to set the temperature.
Is that the purpose of “hold” mode? Or do I need to cancel out any of the default schedules?
Thanks
The Hold Mode overrides any schedules.
If you select “Begin Hold”, without entering an end date/time the thermostat enters “Continuous Hold” mode.
You can then set the temperature manually from the dial or the app.
You don’t have to delete the schedules.
