HMS Hub - Tunes sound
There should be different sounds for the HMS Hub. Right now when you open a door it just plays a short beep/Clank sound, depending on where you put your Hub, you may or may not hear it even with the volume high, I wish you could change the sound to a familiar sound, Like the common ADT chime sound for example.
[Mod Edit] Edited title for clarification of function referenced, which are the “tunes”.
