While home monitoring system is in “Armed: HOME:” a momentary push of the reset button on a contact/entry sensor (or in the app), allows a SINGLE passage through the contact/entry sensor and doesn’t trigger a full-blown alarm, but instead sends a high priority notification to the app and the Hub. (e.g. “A door sensor has been disabled, re-enabling in XX seconds.”
This would allow large houses where the keypad is in awkward positions or to reduce the number of keypads used by the household to allow passage through a door (say to take out the trash, jogging, walk the dog, let the kids out to play) and reduce false alarms.
integrity of the system is maintained due to the temporary disarmament of that sensor because it occurs behind the protected envelope.
