Anyone else having the issue that when set to heat, the air handler fan turns on for about five seconds right when the thermostat calls for heat then turns off until the unit itself turns the fan back on based on it’s thermoswitch for the remainder of the cycle. A/C works normally.
Yes, Lots of us are have that problem. Try removing the G wire until Wyze fixes the firmware.
Thanks! Wanted to make sure it wasn’t just me!
