Hardware device like YubiKey for 2FA
I would like to know, as Wyze implements 2FA, will they offer the ability to use a physical device like Yubikey for 2FA.
How would a physical device like yubikey work on a mobile device? Is that possible?
Easy. The 2FA token shows a number (6 digits in the case of the one I carry) and you type the number into the device you are trying to log in (a Windows PC in my case). Same thing as if using something like Google Authenticator.
