I just have them set to where the light bulb has power but the bulb is not on , if that makes sense…
I will try this for when I notice 1 bulb not turning on . Over the last few times I’ve manually turned on the group and the scheduled rule has gone into effect both bulbs turn on.
None of the lamps are ever turned off since so idk why it doesn’t turn on 1 bulb . But I’ll try the troubleshooting steps when I notice it again .
I have bulbs in a couple of nightstand lamps. They are controlled by a contact sensor in one of the drawers. Open the drawer and the group is turned on. It works great 90% of the time.
Every once in a while only one of the 2 bulbs will turn on. I close the drawer and open it again and then they both turn on.
As near as I can figure, one of the bulb commands fails. My guess is an intermittent connection issue with that bulb.
The first image is your device page. Not your rule page
The second image has the action to turn on one single bulb, not a group. Remove the single bulb action and add the group of bulbs, or add both single bulbs to the action list.
I had a similar situation here I have three wyze bulbs in three different lights and the one post light on my driveway wasn’t getting a connection but the power switch was on all I had to do was shut the switch off on the wall turn it back on and connection was restored I don’t know why that happened but it did but everything’s been good since my point is shut your power to that light and turn it back on maybe it will work again or is it just the rule problem that you’re talking about I have set up all different kinds of rules just playing around with it and they have all worked but sometimes when things haven’t worked I would force close the app go back in and then things worked better give it a try let me know
