I have a v3 that’s mounted to my front window over looking my porch
Recently I started to notice two dots on the top left of the live view that got worse over time and now most recently a line covering the whole left side of the view
I cleaned both the camera lens , window inside and out , but the glare , the dots , and the slashed line still persist .
When the porch light is on it’s their and also when it’s off it’s still their ,
Turn off the status light. On the V3 the status light is on the front and will do wonders at being visible via the glass.
Don’t ask me how I know that…
I get the same thing with bright porch and pole lights at might. It’s normal lens flare. If you can’t move your cam, you’ll ether have to create a hood to block the light from entering your cam’s lens or put something in-between the light source and your cam. My pole lights (and my neighbors’) are enclosed, so I just stuck a small square of electrical tape on the inside of the light’s glass enclosure to reduce glare towards my cams.
