I want to share how I got out of a solid yellow light for a V2 Black Cam and 128GB MicroSD in ExFAT.
Situation: Flashed firmware to 4.9.4.37, default was 4.9.4.38
I did this because I found out I couldn’t download a time lapse and knew that .37 works.
After flashing, the light remained solid yellow. I waited more than 5 minutes and the light never changed.
What worked:
Format card to 2 partitions: One is FAT32 of size 32GB and the other is free space.
The cam worked as normal after flashing. I used the App’s Add Product to add the cam back. I then stopped the cam to re-format the card back to one partition to use the maximum 128GB but switched to ExFAT. The cam detected the full size of the card.
