Can you shut the sensor off? Or put duck tape on the middle to the top of the sensor to stop far triggers that’s what I do with my solar lights on my house and it works. Or cover the sensor completely up and that will tell you that the camera is doing it and not the light.
I can shut the pir sensor off but I prefer using the pir sensor to trigger on the floodlights vs using camera detection and sound events bc the v3’s are very sensitive.
What kind of duct tape did you use for your pir sensor ?
This is a good test , I’ll do this when I get the chance and test it out . Thanks for the suggestion , I’m hoping I can get to the bottom of this weird floodlight issue…
