If you need to suppress notifications from specific sensors when someone is home,
check out apilio.io.
It allows you to set up 1 or more conditions to be checked before a sensor notification will actually
be sent.
For example, if a sensor state changes, and no one is home OR it is between 11pm and 6am
then send the notification, otherwise not.
It also lets you have the same condition (someone comes home, last person leaves) trigger more than 1 action. For example, when the last person leaves my house, motion detection is armed on my front porch Wyze camera AND sensor notifications are sent rather than suppressed.
It’s a little cumbersome to set up with a few IFTTT applets and webhooks required, plus setting up variables and logicblocks in Apilio, but once you have all the pieces in place it is quite flexible and quite easy to debug given the Apilio web dashboard interface.
