Forum Operations Feedback Thread
I personally don’t use Apple products. -shrugs-
I am also using Chrome.
Thanks Gwendolyn, @nerdland . I just disabled extensions and it works. Looks like one of those puppies is intervening.
Glad you got it sorted out! Thanks for letting us know. :slight_smile:
Always a safe bet when having browser issues. Turn off extensions. Now if I could just figure out how to do that with ME?
Hmmm, maybe @StopICU33 knows. I notice they’ve recently switched to the iPad team and they’re probably overflowing with new discoveries!
Hey Stop’, can ya help a feller out? :slight_smile:
Meanwhile, back in the Windows-with-a-keyboard ghetto:
Windows (at least my version) doesn’t have a native Clipboard viewer/editoraster_5  but bare-bones you can workaround thusly:
  1. PrtSc (key on keyboard) to grab full screen
  2. Open Windows Paint applet
  3. Paste (Ctrl+V) into Paint
  4. Crop and add arrows, highlight boxes, text, etc
  5. Select all (Ctrl+A)
  6. Copy (Ctrl+C)
  7. Go to the open post you’re composing here in Wyzeburg and
  8. Paste (Ctrl+V)
I use a light shareware graphics program called IrfanView for a little slicker experience. Properly setup (not that hard) with IrfanView running and minimized:
  1. Crtl+F11 displays a crosshairs over whatever’s displayed onscreen
  2. Move crosshairs to the top-left corner of whatever you want to capture
  3. Drag to the lower-right corner of same
  4. Left-Click captures and
  5. IrfanView opens and displays whatever you defined
  6. Add arrows, highlight boxes, text, etc
  7. Ctrl+A to Select All
  8. Ctrl+C to Copy
  9. Go to the open post you’re composing here in Wyzeburg and
  10. Ctrl+V to Paste
aster_5 It has, since Windows 7, called the Snipping Tool. See subsequent posts.
Yes, I did break my Android tradition and now trying out this new iPad. I really like it so far even though it’s a bit of a learning curve for me. I am happy with this investment. :grinning:
Windows Key + Shift + S key will do the same thing as your second method with IrFanView but it does not require IrFanView
I love :heart: my iPad and really use mine a lot!
I can understand the love affair. :heart_eyes: It’s super nice. All my Wyze cams stream very smoothly and the app is working great so far.
Windows 8 ghetto. No go. :wink:
Jeez, I got that totally wrong, huh? LOL.
You meant turn off YOUR extensions to troubleshoot YOURSELF.
peep :dimbulb:
So, do you guys do all your work here on a tablet with onscreen keyboard?
@rbruceporter @StopICU33
I use my tablets here on the forum quite a bit, but not all the time. I use my Windows 10 pc the rest of the time.
I use my iPhone, like now, and my iPad about 70% of the time, the other 30% I use my MacBook. I have Linux and Windows systems but those are VM’s I use for work.
I use windows Snipping Tool , it’s already in windows accessories , and most of the time I just use the rectangular mode , after making my selection it is saved to my clipboard then I can just paste it into a reply box here
Yeah, I was just now playing with that, prompted by @rbruceporter’s gentle hint. :slight_smile:
I’ve been using IrfanView from the first year which is a LOT of years and I’ve developed tunnel vision to some native features, it seems…
I have been using IrfanView for a long time , my daughter turned me on to the snipping tool,
On my PC I can go to the slide out menu thing bottom right on the taskbar and access the Screen Snip which is basically the same thing as the Snipping Tool , you just get a slimmed down version pop up
I usually hold down the windows key + print screen. Then it goes straight into my screenshots folder. Then I drag and drop it into the editor. All works about the same. :slightly_smiling_face:
Schooled! Thanks y’all! :grinning:
