Firmware 4.X.6.193 was released to the production app on 10/5/2020
Edit: Just for good measure I checked to see if that specific FW was pushed to any devices and the answer was no
Thanks Jason. That firmware update popped up on my device Thursday 10/8 at almost exactly 12 noon. I know (after the fact) it was released 10/5. I open my WYZE app at least three to 4 times daily but the update didnāt show up until 10/8. Would that be normal?
No you should have received a pop up anytime you connected to that cam, that is the only part I canāt explain.
That makes two of us. Thanks for taking the time to investigate.
BTW, I am a retired IT professional and systems engineer, having worked with systems since 1965 starting with
Univac II. Regards, Joe
I donāt understand the forced yet, but server load balancing like Apple does might mean it gets sent to others later.
So you didnāt get the normal "A new firmware version is available. Please upgrade [Cancel] [Upgrade]? A cancel or ādonāt tell me againā would still mean you could upgrade manually.
Win10 Professional, Enterprise, or Education editions allow deferred and paused updates.
