Floodlight pro motion activation continuity?
I’ve had a Rxxx floodlight on my back patio for years. It’s worked well, but has always had one issue I can’t resolve. When it detects motion, it comes on, as it should, but only for five minutes. That’s all. If you’re outside and it turns off, you have to trigger it again for another 5 minutes. It gets annoying when I’m out playing ball with my dogs.
Question - I understand the purpose of the timer. We don’t want a floodlight to get triggered and then stay on indefinitely. We want them to turn off automatically after a set time. However, will the floodlight pro STAY on as long as motion is detected? That is, does motion override the timer? Will it stay on if I’m outside and moving?
It should. Wyze’s floodlight timer restarts each time it picks up new motion, so while you’re out there throwing the ball it stays lit, and the countdown only runs out once things go still. You can also set the light duration in the app, so a longer setting gives you some slack if you and the dogs take a breather.
