Floodlight not returning to automode when using automation to turn on and off
Hello, I’ve created 2 automations to turn on and turn off the floodlight in the app. Everytime I trigger those automation, after turning the floodlights off, it does not return to the auto mode. It no longer turns on the floodlights when motion is detected. Is there something I’m missing. I’ve been trying to figure this out for a while now. Only solution I’ve found so far is to go into the camera and manually press the floodlight icon tien turn it on then off again. That seems to reset it however it is super annoying having to do that everytime.
I also just bought a wyze switch to turn on and off the floodlight with the switch. It also does the same thing not returning to auto mode after turning the floodlight off. Any help or insight is appreciated. Thank you
I have the floodlight v2 also with an automation. You don’t need 2 separate automations. Setup a start and end time in the same automation which works in my flv2. If you don’t have a start and end time in the same automation, it stays in the same status until the next automation cycle.
If you have a single automation for off/on times and it is not returning to normal operations, it may be defective.
