Yes this is the floodlight camera unit .
At first it did , and then now randomly it seems to be getting triggered even after turning off the ir lights to give that over exposure and mirror effect you described . It even got triggered by a cars headlights that was reflecting off my car . Makes no sense this thing sucks
Not really , I kept my settings the same and just turned off the ir lights . It improved the triggering of the floodlights when i stepped out in front of it , before when I had the Ir lights on and i walk outside it would take about 20 seconds to turn on and now when i walk outside it turns on quite instantly but now it seems to get triggered by cars headlights reflecting off my cars which is in range of the pir sensor but it’s just complicated with this device
It’s not good . If you want a floodlight I would really go somewhere else , it’s just my experience with it .
The only reason I have this unit is bc I can add the second v3 for additional coverage . No other floodlight cameras offer this , the only I can think of would be the eufy floodlight cam pro that has the motion tracking camera that will follow a person but that may lead to events being missed out . Which is why I got the wyze floodlight bc I’m able to record 24/7 with the v3 and cover both my entrance to my driveway and my neighbors property who have requested that I cover that side of their property because they don’t have any cameras their yet
And the other camera covers the end where I park my cars and that side of the property but every day it acts differently . Too much of a head ache
I’ve had google nest , eufy , and ring floodlight cameras and i never had as many issues with theirs and since day one of this floodlight camera with wyze nothing but problems . None of the others re engineered the way wyze has engineered theirs , by connecting the camera and the pir sensor together all the other brands have them separate .
Also the cameras go offline frequently , mine go offline about 2-3 times a month . I installed a wyze switch to the switch that controlled the floodlight so I could turn off the floodlight and turn it back on through the app whenever it goes offline.
A lot of others issues with the floodlight , check the reviews to it on the app and websites . Loads of them , to each their own . Tread lightly…
I will wait it out and see if it improves but I’ll definitely replace it with something better
