Hi I’m a newbie with Wyze products. I’m having an issue with the cam on my Floodlight Cam v2. It seems to work fine throughout the wee hours of the night recording the movements of every cat that walks by. But the cam shuts off in the early morning, I don’t have any recording later than 7;45 AM. When I go into event recording it is disabled. There doesn’t seem to be an issue with motion detection as it is tooled on. I am using Bedtime automation which is triggered ar 11pm. I don’t have an end time set. I should also note that I’m using a micro sd card 256gb. Do I have to enable “I’m home” every morning?
Welcome to the Forum, @HotAZGuy! ![]()
I don’t have Cam Floodlight v2, but based on what you’re describing I wonder if the Automation is the source of the problem.
- What can you share about this Automation?
- What other Automations are you using?
- What does your Automation History show? (View this by navigating to the Automations tab in the app and then tapping the house with clock icon to the right of the wrench on the same line as the “My Automations” label near the top.)
If you want to share any screenshots—particularly of your Bedtime Automation if that’s the only one you’re using—then that could be helpful.
