I am trying to flash my v3 pro back to an earlier firmware version. Do I use the same steps as the regular v3 models and what do I rename the flash file.?
The steps are the same. Factory Reset without SD, unplug, insert SD, hold setup, plug in.
4.58.0.3210 is the only prior version available for download. It should not need renaming as the file is already named appropriately in the download package: recovery_wcv3p.bin
Thanks for the info…
