Fix: Wyze Cam v3 Live View on Older Android Phone — Firmware Rollback Worked for Me
I wanted to share a solution that worked for my Motorola Moto G7 Play after my Wyze Cam v3 stopped loading live video.
My setup
  • Phone: Motorola Moto G7 Play (XT1952-4), Android 10, 32-bit
  • Wyze app: 2.50.7.487
  • Camera: Wyze Cam v3
  • Original firmware: 4.36.17.21
The camera continued working on a newer iPhone, but on the Motorola, live view spun indefinitely and eventually gave up. Resetting the camera, reinstalling it in the app, clearing the cache, and trying Wi-Fi and cellular data didn’t help.
What worked
I first rolled the camera back to firmware 4.36.16.6114, but that did not fix the problem.
I then rolled it back further to 4.36.14.3497, and live video started working again with the older app!
Where I found the firmware
The original download was:
https://download.wyzecam.com/firmware/v3/demo_wcv3_4.36.16.6114.bin.zip
I changed the version number in the URL to obtain the older firmware:
https://download.wyzecam.com/firmware/v3/demo_wcv3_4.36.14.3497.bin.zip
The modified URL successfully downloaded the older firmware archive from Wyze’s server.
How I installed it
  1. Download the ZIP file on a computer.
  2. Extract it; the firmware file inside is named demo_wcv3.bin.
  3. Prepare a microSD card formatted as FAT32.
  4. Copy demo_wcv3.bin directly to the card’s root directory.
  5. Unplug the camera, insert the card, and hold SETUP while reconnecting power.
  6. Hold SETUP for approximately 3–6 seconds, then release it.
  7. Wait for the firmware flash and reboot to finish.
  8. Remove the microSD card and test live view.
Result: Firmware 4.36.14.3497 restored live video on my Motorola with Wyze app 2.50.7.487.
Preventing another unwanted update
I also disabled automatic updates where the app allowed it. On my AT&T HUMAX BGW320-500 gateway, I configured a packet-filter rule to drop outbound TCP traffic to port 8605 for the garage camera’s IP address and reserved that IP using Private Fixed allocation.
This is only a precaution: blocking port 8605 is not guaranteed to prevent every firmware-update mechanism.
Caution: Older firmware may lack security fixes, and this result is from my particular setup. Back up your recordings and verify firmware sources before flashing. A rollback may not work for every camera or app combination.
I hope this helps someone else avoid replacing a perfectly usable older phone just because a firmware update appears to have broken compatibility.
