Check out post #1 on this thread. Firmware 4.52.17.26 is listed as v4 Beta firmware. Not sure if Wyze keeps the same firmware number when moving it to general release.
I agree, Iâve had the .26 firmware available for three or four days and I am not updating my cams. No information about an approved public release, the only place it is mentioned is in the Beta Forum.
The latest firmware that supposedly solved this issue did not solve it for me. Today WYZE offered up firmware version 4.52.17.26 to both of my V4âs. No idea why as I am not a member of the BETA team. Anyway, I figured I would give the new firmware a try. It did not resolve the problem I reported elsewhere.
Android App Version: 3.22.1 (979)
v4 Firmware Version: 4.52.17.26
Watching a video from Events or SD shows the stutter in the video playback while using the WYZE app. If I download the event video, the playback looks good without stutter. On the other hand, if I record the video from SD, the video playback contains the stutter.
Downloaded Event Video:
Recorded from SD Video:
Itâs still broke WYZE. FYI for @WyzeJasonJ
Im not seeing this on my end. Iâm sorry its still acting up for you. Do you happen to be viewing video or anything saved before the update? I formatted my cards after updating because it was so bad before it.
Great question and no, everything in my post above was after the update was installed around noon my time today. Iâll format the SD card now and hope for the best tomorrow.
Apple or android? Im on android. Edit i see you are on android.
Also im not sure if its just me or what but the video you post about the stutter stops at 2 seconds and i cant see anything further? Is that the problem you are having?
I hate to be that guy but before everything was so bad for me it was unusable and now everything seems to be working correctly on my end. Anyways good luck my friend
No, the videos I posted play just fine with the problems described within Google Chrome fully patched on my Windows based computer.
I believe this is a separate issue that youâve been having for a while now. Hope it gets sorted out.
The reason it was not listed is because I am the one who puts them on there. That day I was out for PTO and the person who took over was not notified of the release. I only caught it today that the release went out and nothing was updated.
Thanks for your honesty. Now that youâre back, Iâm surprised to see the release notes still donât list that version. Hopefully your dev team can come out with another version soon that fixes the stuttering issues.
Are they looking correct for you now?
That is correct, I have been trying to bounce through the forum to see what issues popped with that release, since there was not a release post.
A lot of @#$%^&*! from me. The update showed up days ago and I could find no information other than it was being tested as shown in the Beta forum. I do not do BETA.
It didnât fix the stuttering problem for me. I see no improvement, but also nothing got worse.
I played six different cloud event videos this morning, all of them were over 1 min. long and none of them had the stop and go stutter. After I updated the V4 firmware yesterday I also âReset Servicesâ on all five cams. I will keep an eye on things today,
Oddly enough .26 introduced this to my v4s. Before this firmware update this week they were fine.
