I’ve got a number of FireTVs and FireSticks around the house and I’m using the Alexa skill to display my cameras on my FireTVs. On one of them (my primary TV) I get constant buffering for one of my cameras but not for another.
Does anybody know if there’s a way to clear the cache, or otherwise reset the “app” that’s running on the FireTV? If this were a normal app I’d go into “Applications” and clear local data, but that isn’t an option here.
I don’t know but I’m sure you could search for it. Meanwhile, is it possible your primary TV / Firestick is simply too far from that camera? The stream might be traveling point to point over your WiFi network.
