Failed to Enable Xnor.ai person detection
Working now :+1:t2:
Awesome! If I may ask, what was the solution for you? :slight_smile:
Downgrade firmware on the cam, restart and upgrade again, after I upgrade app suggest me to activate person detection an just worked.
strange i had 3 cam…only 1 showed up with xnor.ai logo on video.
can someone tell me why?
@newwise Check your settings in the Wyze app > Account > Wyze Service > Person Detection. Turn on! :slightly_smiling_face:
Does it not detect persons or is it just the logo is turned off? Is the Wyze logo on?
check the cameras
settings–>advanced settings–>show wyze logo
you are right
why would someone need to see that logo for?
So did that fix the case of the missing logo?
Advertisement maybe
if i check Wyze app > Account > Wyze Service > Person Detection. All cam are ON.
but i go to settings–>advanced settings–>i chose to disable wyze logo
there is no need to show correct as long as its in person det mode.
If
is a question the answer is yes, no need to display the logo.
