Ok. I spoke too soon. I just now picked up the watch (12:35 pm) some 12 hours after settling it factory reset. But it is still not recording the correct time.
How do I get it to post the correct time? I have two Wyze watches, so it seems something of a challenge to pair the 2nd watch.
Are you able to connect to the watch in the Wyze app? If not, check your Bluetooth settings and make sure the watch is connected. If so, the time should sync. Currently you can only add one of each size watch to one Wyze account.
I have two Wyze 47. Really, it should be no problem to sync two watches in theory simply by labeling each one with a different ID–Wyze #1 & Wyze #2. I’ll try that later on today.
