Extension Cord
Is there an extension cord for the cam pan duo?
Any USB A or USB C extension cable will work (depending which end you prefer to extend, doesn’t really matter). It would be preferable to just buy an A to C cable that is the length you need, but not mandatory. Plenty of extensions and cables on Amazon.
If you need to go more than a total of about 15 feet, it is better to extend the AC power closer to the cam with a standard extension cord.
The extended outdoor power adapter will be ready soon.
