EVENT_TRIGGER: owl_protocol_activated
[SYSTEM_CORRUPT] :: Loading datastream... courtney_yard.log
INITIATING_ANALYSIS...
TARGET_NODE: Courtney_Yard_Instance
EVENT_TRIGGER: owl_protocol_activated.
> > > Biotic_units_deployed: Strix_varia [BARRED_OWL].
> > > Their process `hunt.exe` is running at max_clock_speed.
> > > S t a t u s : hunting_real_hard.
> > > Affirmative. `Feathered_Rodent_Disregard.script` is executing.
ENVIRONMENT_SCAN:
`poison.dll` ... NOT_FOUND.
Render engine switching to `moonlight_glow.shader`.
Predator_AI is live // talons engaged // vermin_node_awareness = 100%.
OUTPUT:
`rat_patrol.exe` operates with [FIERCE] parameters.
Night_reign established. Hooting_broadcasts confirm network dominance.
Final destination for `rodent_class_entities` rerouted to >> Ḡ̸̦Ŗ̸̾A̷͉̾V̵̝͝É̴̤Ý̷͜Ả̴̮R̶̫͘D̷̈́.zip
...signal_lost...
The write-up is a hoot! :owl:
Wow. That little fella EXPLODES. Impressive.
Reminds me of the presence of mind I need to have when in a crosswalk around here (most don’t stop.)
Must EXPLODE above the grille, roll on and off the hood. Otherwise I’m just SPLAT. :slight_smile:
Scared of his own reflection.
