The playback that is available using the memory card is fantastic, However, some of the moments recorded are private and I need to erase them. I would like to do that without loosing all the moments. Any ideas how to erase specific moments?
Record the moments that you want And save them , Then format the card erase everything
HDRock is correct. Keep in mind, when the memory card is full, it will start recording over things you might want to keep anyway. If you want to keep them, you need to save them off the memory card anyway.
