Is there a way to enable the spotlight to only come on during certain periods of time for a specified duration? I want it to record motion 24/7 but don’t want the spotlight to come on unless it’s at night (11pm - 7am) and then go off 30 seconds after motion stops.
the cam settings will let me set the light to come on with motion, and for a set duration but no way to set the timing for during the night
I can see a way to create a rule to turn the spotlight on between set times but can’t see how to turn the light off
You can do this thru Rules, however 1 minute is the minimum time.
You will need to disable the Spotlight Control in the Settings → Spotlight Settings (from Auto to Off) that turns it on automatically in any low light situation regardless of time.
@SlabSlayer thanks…. I was doing this on my phone and didn’t realize there were options off screen. I only saw the option to turn it on. just had to scroll down. Thx again.
