I have zero knowledge on all things electronical. Our home came with blue electrical boxes pre-existing for a security system. How can I connect the power source and/or internet to this box?
I also have two kinds. One has a red wire the other a blue wire .
It’s impossible to tell from your photos what type of cables these are or where the other end of them is. You would need to have an electrician or home automation specialist come out to evaluate. But don’t you have an electrical outlet nearby that you could plug the camera’s power block into?
As for internet, these cables may be able to carry ethernet (for internet). That too would need to be evaluated in person. However, Wyze Cams connect only over wifi, so this would be irrelevant as far as the Wyze Cams are concerned.
