Duo Cam Lost Connection… seriously?
Ok, I need to reboot my DuoCam, but this requires popping the Cam off its mount, removing the battery, turning off the power to my transformer (circuit breaker), putting the battery back in, and turning power back on.
And there is no way of just removing the battery and always running off the transformer?
Is this correct?
Oh, and if you have the plug/lighting symbol indicating you are using the transformer and are charging, where can I see the charge percentage. The app is flaky as hell about showing that.
The symbol I’m seeing is a plug overlaid a battery. Both grayed out. And there appears to be a white lighting bolt over that. IIRC this was the same thing a year ago. What is up with Wyze? Are they trying to lose business?
