Doorbell pro wont detect motion with cam plus
My doorbell pro won’t detect motion when on cam plus but it does with no plan. This started several months ago and contacted support and did everything they ask and nothing worked. Anyone else dealt with this?
rosalie, when Cam Plus is active on a battery Doorbell Pro, the plain motion alerts are replaced by the AI detection types, so a camera that alerts fine without a plan can look dead with one. Open the doorbell in the app, go to Settings, then Event Recording and Detection, and make sure Event Recording is on and that Person, Vehicle, Pet and Package are each switched on individually. Also check that your detection zone and sensitivity were not reset when the plan applied, since a small zone can miss everything. If those are right, try removing the doorbell from Cam Plus, then adding it again from the Cam Plus page in the account tab, and then power cycle it. Tell us whether the alerts come in under Events or not at all, because that points to either detection or notifications.
All the settings are correct. This happened earlier this year, I tried again the other day and its the same issue.
