Do any doorbell cams had a view width of 20'?
I need a doorbell camera that can see 20 feet to the right and also down to the sidewalk from the 2nd story.
Are you able to use a regular Wyze camera to monitor your door? I have a Wyze Cam v3 aimed out a window near my front door. I have a standard doorbell, but my v3 cam see my porch, walkway, driveway and street.
I’m in an HOA and don’t think they allow cameras, except for doorbell cameras. I don’t see amything in the rules but they’re pretty stringent and don’t want to go down that path - yet. Everyone but me has a doorbell camera though.
Why can’t you put a doorbell camera by your door if everyone else has one ?
I think your specification (“camera that can see 20 feet to the right”) is about more than just “view width”, because every camera should be able to see that width at sufficient distance. Have you looked at the Doorbell Comparison Chart? You may want to consult that and consider a few things:
  1. At what distance from the camera do you need 20′ of horizontal coverage?
  2. At what angle and height do you intend to mount a video doorbell?
  3. Do you have access to 3D printing facilities?
If you know the distance at which you need your specified width, then you should be able to do some calculations based on a given camera’s field of view (FOV) in order to get an idea of whether or not that camera would provide the coverage you desire. At that point, I think the challenge is mostly just getting the video doorbell mounted at the proper height and angle for the view you want, and that’s where the 3D-printing community can be helpful in compensating for Wyze’s limited mount angles.
FWIW, I started with Video Doorbell v2 and then modified a 3D model to fabricate a mount with the downward angle I wanted and was generally pleased with that result. I’ve also tried Battery Video Doorbell, which has a pronounced fisheye as a result of its wider FOV, so maybe that’s what you’d want to consider for the width you’re trying to capture. I noticed that you tagged your topic for Video Doorbell Pro, and—according to the comparison chart linked above—that model (which I believe may be no longer sold) has the same FOV as Battery Video Doorbell.
Would your HOA mind a vase inside one of your windows?
Yes, I estimated the horizontal view radius I need to be about 160 degrees. I’ve found 2 so far with that feature. Wyze has 2 but they only go 150 degrees. Thanks for the link.
You do know that Wyze makes one of those, right? :wink:
I do now. Here is the Wyze link.
I like it, going to try to find a doorbell cam 1st. Thanks it’s a def option.
This is my configuration as I too have mounted my camera behind my 2nd story window to see who comes on my sidewalk and when. I just use the detection area to map out only the sidewalk so that I don’t see car traffic. Amazon.com: oioaahkeo Angled Window Mount for Wyze Cam V4, 20 Degrees Tilted (Up/Down/Right/Left) Adhesive Mount for Wyze Cam V4, V3 and V3 Pro(Black) : Electronics and Amazon.com : WYZE Cam v4 (Latest Model), 2.5K AI Security Camera, Indoor/Outdoor Cameras for Home Security, Baby Monitor & Pet Camera, Vibrant Color Night Vision, No Subscription Required, Free Expert Help : Electronics and Amazon.com: SANDISK 32GB MAX Endurance microSDHC Card with Adapter for Home Security Cameras and Dash cams - C10, U3, V30, 4K UHD, Micro SD Card - SDSQQVR-032G-GN6IA : Electronics
