Disappointment
Wyze cam OG Telephoto is a big disappointment. Motion detection is very sensitive to light changes which makes outdoor usage impossible… The range of view is very narrow.
Well it is telephoto, range of view goes down as zoom goes up :thinking:
Reducing the Detection Sensitivity will tune the cam to your specific use case environment. Wyze Cams are not self tuning. You have to adjust the settings for your unique use case and FOV.
As @bryonhu mentioned, it is a static 3x zoom to reach out and see things in focus farther away, like looking thru a monocular, the higher the magnification, the narrower the FOV.
