Did I break my V4?
I accidently dropped my V4 on the floor and when I go look it has this odd color. Like my color scale got messed up? I rebooted but that didnt fix it.
The shutter for the night vision is stuck. Try tapping it or shaking lightly on the top and sides If you dropped it hard it might be stuck hard.?
You can also try switching the night vision setting on the app from on/off/auto a few times.
I tired toggeling night vision, I dropped it from about 6 ft to the floor. I will try tapping?
Oh cool…soft tapping got it back to normal. Thanks for the quick reply!
Stop abusing your V4 :rofl:
Awesome! @smhagen1 unlocked Barbie Mode! :grin:
In addition to tapping, I’ve also seen a :magnet: used (saw a video on Reddit once) to get the IR filter “unstuck” by moving the magnet around the camera body. I’m just stickin’ that here in case this happens again.
Glad you got 'er fixed! :+1:
I once tried attaching a V3 to a floor lamp. I had this crazy idea that I just needed to affix a neodymium magnet to the lamp and let V3’s magnetic base do the rest. I got shades of pink and red in the view.
Sometimes, hitting something with a hammer :hammer: is actually an effective troubleshooting technique!
