Should I have a “Detection Zone” switch under “Detection Settings” that allows me to set up a detection zone with the use of the green-colored zone tool? Because I have Cam Plus and it is absent from my Detection Settings.
Any insight is appreciated…
Can you send a screenshot of the settings page?
Sure.
Tap on the words, “Detection Zone” and on the subsequent page, toggle on “Detection Zone”. Then set your detection zone area and tap “Save”.
A-ha! I can’t believe I completely missed seeing that altogether. I was looking above the sensitivity sliders. Got it now - thanks!
No problem… glad to help!
