Defective cam or incorrect settings
Having an issue with the cam. Had it about 10 days now and it just started showing flashing streaks in the live feed and the recordings. Cant upload vid as a new user…
Well, the description certainly doesn’t sound normal. I doubt you can fix what you are seeing with settings, so you should probably go straight to submitting a support request:
https://support.wyzecam.com/hc/en-us/requests/new
Welcome to the community, @Geoschiss. I have increased your trust level, so you should be able to post that video now. :slight_smile:
Screenshots:
For what it’s worth, Wyze is sending a replacement unit. Still would like to know why it crapped out after about a week
That’s interesting. I’ve never seen that before. Do you get the same thing in daylight?
