Has anyone else experienced their Wyze cams just dying? I had 5 of them just not connect, batteries don’t hold a charge after a year (and this is without charging the unit continuously), I’m starting to question the durability of these cameras. For reference I’m using Wyze cam v4 and some v3 ones. Customer service doesn’t even respond to my inquiries.
None of those cams use batteries.
The outdoor wireless camera does.
You never mentioned any WCO cams. Those are very old cams so yeah, the batteries have probably hit the end of their life.
As for your wired Cam v4 and Cam v3 cameras, the power bricks and power cords can go bad. If so, try swapping with working cameras to test.
Welcome to the real world - electronic devices die. This is particularly true for cheap electronics.
I just looked at my spreadsheet - I have had six of my 56 Wyze cameras die. That includes four V2 cameras that were all activated in 2018, a V2 that was given to me used in 2021 (I don’t know how old it was), and a V3 that was activated in June 2021 and died 11 months later (and was replaced under warranty). My oldest camera was activated on 2 May 2018 and is still working, although it no longer detects a uSD card. I have had a couple of the wall warts die, but those are so easy to replace.
You mention you are using Wyze Cam v4 and some v3’s, as stated none of those use batteries. Which battery cams are you having an issue with? How are you attempting to contact support? I would like to see why they are not replying.
