Damaged oulets
I had 2 indoor wyze cams with in 2 months damage 2 seperate outlets. There’s still power coming from one of the plugs in both outlets, so I just switched it. But it’s only a matter of time before those may blow. Has this happened to anyone else?
The adapters shouldn’t be pulling enough current to damage a power receptacle. Are your receptacles old and maybe not making a good connection? You should probably call someone to replace them with new ones.
