I have all V3 cameras and CAM UNLIMITED. Why is there no cooldown settings? I am missing video cause the person is still moving but it stopped recording after 13 sec. That camera is in the cam unlimited bundle. I also noticed this on my other cameras as well. One other article from May says it was being worked on but looks like they never fixed it
Sounds like you may need to up your motion sensitivity setting or make your detection zone larger. What is it The motion sensitivity setting currently set at? The subject may be moving, but slowing down enough to not continually trigger the motion sensitivity threshold.
Sorry it took so long to answer. I am trying to figure out how those settings work. What does high sensitivity mean? I think it means it will pick up everything right?
The higher the number, the more sensitive your motion detection threshold will be. Best is to start at 100, to see everything that the camera is detecting. Then back it off from there to find the sweet spot where the detected events are what you want to see.
