Controller doesn’t display “open” or “closed” anymore
Why does this happen? I had to calibrate again.
I got a notification the garage door was left open, when I checked it was closed. I tried reconnecting and resetting through the app without success. Then I recalibrated through the app and that fixed it. This has happened before, possibly it should be reported as a bug.
Update:
The camera and controller went offline again after the original post. It required power cycling and restarting and resetting the camera and controller. Then I had to again recalibrate the controller. The Wi-Fi signal has full strength and the firmware are both up to date.
Added: the time stamp was reading January 2024. I had to sync the time to get it corrected.
Continuous on off reports from controller
