Why is my contact sensor blinking every 5 seconds when nothing is moving? (signal strength is good)
Usually that’s the pairing mode indicator? Or the sensor could be “stuck” detecting motion. Carefully pry the case open and remove the battery. Wait for a few seconds and put the battery back in and see if that resets it.
Ok, I’ll try that. (the sensor is paired and it does work fine)
Please do let us know how that works
I had to remove it from the Wyze app and then re add the sensor and it worked!
Glad it cleared up but sorry you had to go that far. If it should happen again please let us or Wyze Support know.
