Connecting Wyze
My condo community has a common wifi network similar to a hotel. How can I use my Wyze camera through this network?
Does it have a splash page for signing into the internet?
No. The condo association WIFI option appears in the menu to select from but no sign-in or password is required to use it. ISP is not the same as our cable TV provider.
theres your issue then. the cameras require a secured network. if there no password they won’t be able to use that network.
At extra cost you can use a travel router to interface your camera to an incompatible network, but your camera would be insecure once it appears on you condo network.
