Color cycling with Wyze color bulb
So, had this feature happened yet? A guy died the street had guys lights cycling between red and green fire Christmas and I can’t do that with my Wyze bulbs so they are just one color ask the time. Boooo. Even if they just added a loop function into the rules it would allow us to own light cycling. Please let me know if there has been any update on this.
Thanks!
There has been no capability added to the Wyze color bulbs yet to do designs or effects.
The only way this is possible still is to add the Wyze color bulbs in a group with the Wyze light strips.
Is this request ever going to happen?
I don’t see this happening natively in the Wyze app anytime in the near future. They set the status to maybe later (which also means maybe not ever but they haven’t totally dismissed it as a possibility, it’s just not currently under consideration or on their road map).
However, there are 3rd party integrations that allow you to do this with your wyze bulbs. I personally do this using Home Assistant.
I created a routine to cycle my Wyze color bulbs with Halloween colors. I wanted to have each bulb independently change to a random Halloween color every x seconds. So I installed home assistant, then installed the Wyze integration into it. Then found the bulb names and entered those into an AI and told it to make an automation for me that would do that automatically when I turned the routine on. It did it all for me. I just copied it into a new automation and it worked great. I made my own modifications later such as seeing it up to only do that when I flip a toggle I named “Holiday” and sometimes I go change what colors I want to allow it to switch between.
I believe you can do the same thing with a few other third-party platforms too. I’m just personally familiar with having done it successfully through home assistant.
Wow just bought these and after reading this thread…super disappointed. Seriously can’t color cycle?! Wtf wyze wish I could return these but apparently that isn’t an option either.
Still anxiously waiting for the Bulb Color to be able to cycle through colors.
It’s coming…. Wyze Week 2030. Be here before you know it.
