Clips Cut Short
This issue occurs on all my cams, V3 & V4. For instance, I live at the end of a small street with a cul-de-sac. I have a V4 on the curbside mailbox set to the highest sensitivity with no detection zone set. I can see the entire street and circle with no obstructions in the field of view. It has a Sandisk Ultra Endurance card and is set to continuously record. This is a new card. I replaced an older card thinking it might be the source of the issue. I have changed out the camera to determine if it was an issue with a specific unit. I also subscribe to Cam Plus. The WiFi signal is excellent and I am using the included power block and cord. The camera will detect movement further down the street as a car approaches the camera and begin recording. It will label it movement but not vehicle. However, the clip only lasts 5-10 sec on average and ends before the car makes the entire circle. This occurs both day and night. The same thing occurs with people walking up the street toward the camera and around the circle. There is no stopping or pausing of the vehicle or person . I can view the entire event by going to the disk. However, in the spring and fall, it will pick up a random piece of dust that briefly passes the field of view and immediately exits. It will also pick up a leaf blowing intermittently across the field of view which pauses for many seconds before another burst of wind moves it again. The camera will often record a 30s - 5 minute clip of that nonsense and label it as a vehicle or person. I know that I can’t manually adjust the clip length. This is exactly why I began using a disk to continuously record. I can’t afford to not see the entirety of an event due to legal reasons. Has anyone experienced similar issues or have suggestions?
If you have a micro SD card on continuous there is no “clip”. Is it only the cloud video (cam plus) clip that is having issues? Being cut short and not being able to identify “smart” objects both point to a connectivity problem, either with wifi or internet. Keep in mind signal strength is just one measure, signal quality and available bandwidth are a totally different story. Reaching a curbside mailbox from inside your house (depending on the distance) will subject the wifi signal to a lot of interference from neighbors. Plus the signal then has to get back from the cam to your router, and the cam signal won’t be as strong as your router.
You can try different channels, moving your router (higher is better, and you want line of sight through a window if possible), and tweaking settings in your router. For example, lock your 2.4ghz to 20mhz channel width instead of 20/40 as 40mhz can cause a lot of issues. Disable any “beamforming” features if you have them too.
But can you confirm the whole video is on your SD card? If not, then it sounds like something malfunctioning in the cam.
V4 cam- the dowloaded event video has two short skips in it, the original version played on my iPad Pro does not. Video AI tagged as FedEx.
It is the cloud clip that is cut short. I am able to view the entire event on the card because I record continuously. The mesh router was purchased within the last year and an extender is placed on the front porch to prevent interference by the brick exterior. The extender is approximately 150 ft from the camera. The modem is also new. My internet download/upload speeds never drop below 500/25 respectively.
I live alone and do not game,. I rarely stream movies. I have a phone, tablet, laptop and desktop. Only one at a time is used. I often work 14 hour shifts so there is not a lot of traffic. This issue occurs regardless of whether I am at home or away.
As I mentioned, this occurs with all of my cameras. I was just using the mailbox camera as an example to emphasize that there is continuous close movement in the field of vision of the camera and I’m only getting a truncated clip of a vehicle entering the circle instead of making the entire circle.
Is the extender hard wired back to the main router? If not, that’s at least one of your problems. The brick exterior will still impact that extender, and a wireless extender cuts the already low 2.4ghz bandwidth in half. Of course the camera shows a strong signal if you have an outdoor extender, but the extender to router connection is probably where your issue lies.
As far as your other cams, not sure if they’re also using mesh/extenders or the main router, but it sounds like you’re just exceeding what your 2.4ghz setup is able to handle. Mesh isn’t always a good thing, it brings its own set of problems. The weakest link in your wifi affects the whole network, that outdoor extender could be dragging the throughput of your entire 2.4ghz network down to a crawl.
Since it happens on every cam, one quick test would narrow it down: move one of them inside near the main router for a day, pointed somewhere with steady movement. If its cloud clips run full length there, it’s the path through the extender. If they still cut off after 5 to 10 seconds, it’s more likely on the Cam Plus side, and worth a support ticket with a couple of example events.
