It would be very nice if a camera’s network setup could be changed dynamically, via the app, instead of having to climb ladders to reprogram the cameras.
This feature is available for many cams in the app now, are you running the latest version? Not sure if the Solar pan has it but all the models I have do.
You see it for your Cam OGs? I’m seeing only for my Cam Pan v3s and Cam v4s.
Welcome to the Forum, @rick16! ![]()
Thought it had appeared at the same time the new interface and auto-update disable did with the last update, but guess I was imagining things. Panv3 and Camv4 have it but not OG or OG-Tel.
Although the v4 is greyed out and says “you must update device firmware to use this”. Firmware is up to date ![]()
That comports with what I’m seeing, as well. Also, Cam OG doesn’t have the Reorder option in the “menu bar” that these others have. I think those and Cams based on them are always going to be oddballs with their UIs, or at least that’s how it seems.
That button is disabled for me on Cam v4, as well, but I’m still running 4.52.9.5332 on those and haven’t yet updated to 4.52.9.6119.
I’m on 6119 and still greyed out and giving that message. Guess it is just a tease. Not that it is a feature I really need anyway.
Probably wasn’t supposed to appear in the app until the next firmware version or something.
It’s the solar powered cameras that I’m referring to. I do see where it’s an option, although grayed out, on non-solar cameras. I have all the latest software. Thanks for the replies.
