I think I actually went quite reasonable. Bumped from 500 to 775 HP after dyno tune, and far from the loudest I’ve ever owned. That’s about as far as you can go NA on the 427 without starting to have reliability concerns or affecting drivability. And I’m not a fan of forced induction.
At 18 years, I’m eligible for “visual only” emissions inspection, and since I deleted the cats, will have to fashion up some decoys before my next inspection in the spring.
Dave27, I did not know you were a car guy (or a Vette Guy). If you have a 427 in there it must be a Z06. Hang on to it. Here is my 1981 C3, which I sold when I got married.
Yes, Z06, bought it new in 08, no plans of getting rid of it, I like low tech V8 with a stick shift and haven’t liked the newer ones. And the LS7 is a killer engine, very easy to get more power out of. Though I’d consider going to a 1970 Chevelle SS with the LS6 454 in it. Maybe if I had another garage bay.
And of course this total engine overhaul came about because I had one $20 lifter that needed to be replaced. A dozen "while I’m at it"s later, here we are. I mean if you have to tear the top half off anyway…
I do too (though it is a bit of a Ferrari rip off) but it is way too complex, and yeah, no stick shift (even though they did a survey and found 25% of people would want one). Some of the other brands are doing “shift by wire” which isn’t the real thing, but close enough to satisfy that customer base and not a total redesign.
I also like American muscle, the high-revving exotic thing, not as much. Although the new ZR1 is incredible, if I were rich and had a big garage, there’d be one in it.
When you hear about celebrity car collections, Jay Leno’s name always comes up. If you like classic American muscle cars, check out Richard Carpenter’s car collection. He has a 1957 and a 1966 Corvette.
My broken lifter cost me about $6,000.00. I dropped the push rod down the hole into the block while tryin to remove it so I decided to get the engine rebuil, stock rebuild to run on unleaded gas. Still has 360 HP for a 3600 lb car.
Here is the original window sticker from my Vette in post #2 above. MSRP was $17,193 and the dealer let me have it for $15,400. Interest rates in 1981 were around 19%, so the car sat on the showroom floor for a long time. The dealer’s body shop did the custom two-tone paint job to try to sell it. That is why the window sticker lists the color as silver. Every pinstripe was painted and not tape.
My partially collapsed lifter (no mistaking that sound in a single cam pushrod engine) ended up running me more than that.
-Have to remove the intake, might as well put a much higher flowing one on.
-While the intake is out, might as well put a larger throttle body on it (I mean, the new one supports both sizes).
-Need a bigger cold air intake to feed it
-Have to remove the heads, might as well have them ported and polished and replace all the seats, valves, valve guides, go for double springs, hardened pushrods, etc.
-Have to remove the exhaust manifolds, might as well put long tube headers on. And get rid of those pesky cats.
-Sure, you can replace the lifters without removing the cam. But would want to inspect the cam for any damage from that lifter (let’s pretend I don’t have a borescope), so while it’s out, might as well put a higher lift lopey cam in.
-Since have to remove the harmonic balancer anyway, replace that with a race one since the OEM rubber is a known failure point.
-Need a new triple disc clutch to handle the additional power.
-Need a dyno tune to account for the new cam and higher airflow (and delete the rear O2 sensors)
And while I’m at it, might as well replace that lifter (and the other 15)
“While I’m at it” gets very expensive. Then all the incidentals (new belts, new gaskets/seals, fluids, etc) are just the icing on the cake.
I keep all my window stickers too. I’m surprised the fuel economy rating went back that far, thought it was a more recent thing. Sad thing is my Z06 is more fuel efficient than my truck (well, it was, TBD going forward).
This is why I never got married, I wanted to keep my toys
My thought exactly. The engine block in my 67 GTO was not original and was out of a Larger Pontiac, compression raito with the original heads was 10:5 to 1. I figured the same since they had to take it apart, just replace everything, machined the crank, all new pistions and rods, different new iron heads, valves, springs, lifters, seals, new timing chain, oil pump, fuel pump, bearings and all the other important guts. Has run great since 2017.
That page was last updated 2008, guess he lost interest in sharing or just got too damn old. I hope to have an early 70s Chevelle SS before I’m too old to enjoy a classic muscle car. Though mine now sounds (and smells) like one. Still getting used to the new clutch and cam.
I’ve only got about 22,000 miles, but at 18 years old, wanted all the seals and stuff changed out so got all those kits put in. The heads on the LS7 engine are known for failure of the valve guides and needed to be beefed up to handle the high lift cam anyway. I just stuck with a new stock timing chain, they’re pretty bulletproof on this engine (but no sense in not changing it while in there). Should still be around 11:1 (stock) compression, the combustion chambers are a bit bigger but the heads were milled down some to balance it out. I considered going to 12:1 or higher but would probably have needed to add methanol injection. As fun as blue flames out the exhaust are, that seemed a bit excessive.
The bottom end on this engine is good for over 1000HP so didn’t need to do anything in there. We’ll see how the stock engine mounts hold up to this cam, luckily they’re pretty easy to swap out if needed.
It sounds like something out of the 70s now. There are plenty of options to get over 1000HP out of this engine but they all sacrifice longevity, I’m happy with the compromise.
To much of a good thing. There is a nice long straight street one block west of my house. One afternoon I heard a loud revving engine followed buy the sound of squealing tires, soon to be followed by a loud crash. Next sound was sirens
I walked over to see the mangled remains of a nice blue Corvette with a nice chrome covered engine that had one of those sky high superchargers. The guy took out a fence and a power poll next to a house. The good part was the engine was still good but the rest of the car not so much.
I had a close call when I was like 22, had a solid rear axle Camaro. Once those start to fishtail, they don’t stop. Luckily managed to avoid hitting anything and my underwear was unscathed. Age has brought more wisdom as to when you’re “at the limit”. Though stability control helps too, this one actually has a mode where you can turn off traction control but leave stability on. If you start to “get loose” it taps one brake to straighten you back out. The newest Vettes have a “burnout mode” where it holds the front brakes for you like a line lock, sort of takes the fun out of it.
I’ll be taking it easy until everything (especially the new clutch) is broken in.
I am married bought a new 2025 C8 and have lots of kids too. You sometimes find an understanding wife. Had a C7 I bought new as well before my C8. 495 hp is enough for me, and the performance exhaust option wakes the neighbors if I enable it.
One of the city cops told me I was to old to be squealing the tires on my GTO. I told him it wasn’t my fault it was just that the TH-400 auto transmission that is in the car has a beefed up shift kit in it and is rated for twice the horsepower that the car has, I told him it just shifts hard by itself. He just rolled his
The one on the C6 isn’t user adjustable (other than switching from 3500 RPM open in regular mode to 3000 in performance mode), the dealer pulled the fuse out the day I bought it and those flaps have been open ever since. I actually just added a switch so I can close it if needed (annual inspection, get pulled over, etc) since I knew it would be a lot louder after this. I wasn’t even sure if the flaps would move after so much time. I like the look of the C8 but I want a manual and low tech engine. But if I was stupid rich and had a big garage, there would be a C8 ZR1 in it too. Not ZR1-X, no sense in adding all that weight and complexity just for a faster launch.
