The cam vertical range is fine but will not point down to pick up my front door. Mounted over a second story window. Is there an alternative bracket that will pitch the basic angle down. There really is no need to have this camera point to the sky.
Depending on what it is mounted to, there are various angled or wedge shaped things you could mount between the cam and wall. I’ve cut angled pieces of wood and painted them to match the siding for various other things mounted on my house (in those cases to make them sit flat on the siding, but same principal).
It has a 70 degree range of motion vertically so in theory it should go down about 35 degrees from straight out. I’d think you could add a decent amount to that as a permanent “down tilt”.
