Can’t add cameras to monitoring. It only allows 3 every time I drag another camera up it lets me drag it up but want keep it there. I don’t think the pan came can be added however I have several others that want stay when I drop and drag to a new page.
What app version are you using? What happens if you drag everything out of your pages, clear the app cache(s), close the app, re-launch, and try again? I’m not having problems dragging Cams into or out of pages on the Sort Cameras screen in Monitoring, and that includes Solar Cam Pan, which you show in the “AVAILABLE CAMERAS” section of your screenshot. This is with Android app v3.19.0.935.
Hi @rnrbodyworks , could you please try reproducing the issue once more, then submit a log right after it happens and share the Log ID with us? Thanks!
2532672 log id
@rnrbodyworks, thank you for the information about your app version. I updated a phone to Android app v3.20.0.941 to see if that would break the page editing feature for me, and it doesn’t. I can still move Cams into and out of pages in the Monitoring tab—including Solar Cam Pan—as before. After reading the updates to this topic, I almost expected the new app version to break the feature and was planning to recreate the failure and submit a log so that I’d have another Log ID to post here, but there’s no apparent failure for me to log with this. ![]()
@WyzeEnTing, thank you for looking into this! ![]()
Uninstall the app and did a restart still same issue? Dunno??
