First of all, I really like the Lock Bolt v1 for being a non‑IoT solution. I don’t want or need Internet connectivity for my use case, and I’m perfectly happy to copy and paste a temporary access code for family or friends when needed.
With that said, it’s nice to see that v2 incorporates a physical key as an additional way to lock and unlock the door. I installed one yesterday, and honestly, the new unit looks quite sleek and modern. However, I haven’t been able to figure out whether it’s possible to completely disable Wi‑Fi on the v2. I’m hoping to do this to minimize the attack surface and potentially reduce power consumption so the battery doesn’t need to be replaced as often.
I’ve considered a workaround: setting up a temporary Wi‑Fi network just to complete the initial setup and update the firmware, and then taking that network offline afterward. My question is, would the lock end up draining more battery by continually searching for an SSID that no longer exists?
