Can the Video Doorbell Pro be powered by an external plug-in transformer?
I do not have doorbell wires for power and would like to avoid having to recharge the doorbell. I’m wondering if it would be possible to have a plug-in transformer near the doorbell provide the needed power? If so, is this something you sell?
Yes, In the past I used the following as I was testing and setting it up before installing:
I still have it and use it on occasion, when I replace my doorbell with the latest ones.
Yes, I did this for a long time with the Video Doorbell Pro until I switched and bought a Duo Cam Doorbell.
I just bought a cheap one on Amazon that said it worked with other Video Doorbell brands. Worked so great I went and bought more of them to use with more doorbells. I highly recommend it. It’s so much better than having to recharge the batteries.
