Can I determine hardware info from the web viewer?
Is it possible to determine from the web app, if you have SD cards in your cameras? Or must you go outside and pull them down to check for card presence. Or lastly, can I use the iPad app to check for card presence?
The only way to find out if there’s an SD card installed is via the Wyze app.
